Use this procedure to display information on FA-created Switched UNI (ELAN) I-SIDs.
Display information on all Switched UNI (ELAN) I-SIDs.
The following sample output displays, for example, the I-SID information on one of the peer switches of the FA Server, in a dual-homed SMLT configuration.
Switch:1>enable Switch:1#show i-sid elan ========================================================================================== Isid Info ========================================================================================== ISID ISID PORT MLT ORIGIN ISID ID TYPE VLANID INTERFACES INTERFACES NAME ------------------------------------------------------------------------------------------ 2002 ELAN N/A c2002:1/10 - - --- - -l- - EXTRSERVER_1 4000 ELAN N/A - c4000:1 - --- - --r - EXTRSERVER_12 4001 ELAN N/A - c4001:1 - --- - -l- - EXTRSERVER_101 4030 ELAN N/A - c4030:1 - --- - --r - EXTRSERVER_102 4051 ELAN N/A - c4051:1 - --- - -l- - EXTRSERVER_103 10200 ELAN N/A - c200:1 - --- - --r - EXTRSERVER_2 c: customer vid u: untagged-traffic All 6 out of 6 Total Num of Elan i-sids displayed ORIGIN Legend: C: manually configured; D: discovered by FA or EPT M: FA management; E: discovered by EAP; A: auto-sense l: discover by local switch r: discover by remote VIST switch
The I-SID TYPE field displays once for each I-SID. The I-SID TYPE of an I-SID that is either learned through FA mapping assignments or configured as an FA management I-SID, is always ELAN. If a platform VLAN has the same I-SID value as that of the I-SID in an FA mapping assignment or in an FA management I-SID configuration, then the platform VLAN is associated with the I-SID endpoint and displays in the VLANID column.
Display MLT I-SID information for MLT 1.
In this sample output, the ORIGIN field indicates the origin of the I-SID endpoint.
Switch:1>show mlt i-sid ===================================================================================== MLT Isid Info ===================================================================================== ISID ISID ISID MLTID IFINDEX ID VLANID C-VID TYPE ORIGIN NAME BPDU ------------------------------------------------------------------------------------- 3 6146 3 N/A 33 ELAN C --- - --- - ISID-3 ------------------------------------------------------------------------------------- 1 out of 1 Total Num of i-sid endpoints displayed ORIGIN Legend: C: manually configured; D: discovered by FA or EPT M: FA management; E: discovered by EAP; A: auto-sense l: discover by local switch r: discover by remote VIST switch
Display I-SID information on the port 1/10:
Switch:1#show interfaces gigabitEthernet i-sid ======================================================================================= PORT Isid Info ======================================================================================= ISID ISID ISID MAC PORTNUM IFINDEX ID VLANID C-VID TYPE ORIGIN NAME BPDU SUNI ---------------------------------------------------------------------------------------- 1/1 192 27 N/A 4000 ELAN C --- - --- - ISID-27 FALSE 1/1 192 270 N/A 4001 ELAN C --- - --- - ISID-270 FALSE 1/1 192 309 N/A 309 ELAN C --- - --- - ISID-309 FALSE 1/1 192 401 N/A 401 ELAN C --- - --- - ISID-401 FALSE 1/1 192 1001 N/A 1001 ELAN C --- - --- - ISID-1001 FALSE 1/1 192 1111 N/A 1111 ELAN C --- - --- - ISID-1111 FALSE 1/1 192 1121 N/A 1121 ELAN C --- - --- - ISID-1121 FALSE 1/1 192 1201 N/A 1201 ELAN C --- - --- - ISID-1201 FALSE 1/1 192 2001 N/A 2001 ELAN C --- - --- - ISID-2001 FALSE 1/2 193 38 N/A 4000 ELAN C --- - --- - ISID-38 FALSE 1/2 193 310 N/A 310 ELAN C --- - --- - ISID-310 FALSE 1/2 193 380 N/A 4001 ELAN C --- - --- - ISID-380 FALSE 1/2 193 402 N/A 402 ELAN C --- - --- - ISID-402 FALSE 13 out of 152 Total Num of i-sid endpoints displayed ORIGIN Legend: C: manually configured; D: discovered by FA or EPT M: FA management; E: discovered by EAP; A: auto-sense l: discover by local switch r: discover by remote VIST switch
The following table defines parameters for the show i-sid command.
Variable |
Value |
elan |
Displays all ELAN I-SIDs. |
The following table defines parameters for the show mlt i-sid command.
Variable |
Value |
<1–512> |
The valid range for MLT ID. |
The following table defines parameters for the show interfaces gigabitEthernet i-sid command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
